  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah, those ones would be good for that job. As long as no-one plans to get me, I am taken after all! (I know, no-one wants me anyway, don't come out with the harsh comments noe expected!) I don't think she would like to share Paul.
those ones? that job?
damn she does sound like a pimp in the making.. hehehe.. :P
Seeya Cam! I will tell them to be there. If you are lucky the name unmentionable one will flash her t#ts for you all just like she did at Narrogin Rev Heads, nit that she was wearing a proper top in the first place. She has also worked as a topless barmaid so have fun!
