  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i have to triple post cos i was posting in the ads :)Besides im not as bad as Paul - will never be!!!
Whats on next - i have no TV guide :P thats what happens when the olds arent around to buy the paper! wont be around this weekend either :)
they are advertising it on TV - the national driving test - they want volunteers to head up against the other states - to see which is the better drivers - i reckon we should get SAU groups from each state together and battle haha
If it involves knowing the road rules and driving Miss Daisy then we are screwed.
If it involves drifting , circle work , high speed lane changing on the freeway and top speed runs on single lane roads , they might as well give us all the prize now.
:P
Cheers
Ken
I will volunteer for the best drivers test..... as long as they allow you to drive your own car and don't give it a top to tail inspection before hand :)
Hey is anyone here a " Survivour Fan " ????
Im watching now .... hehe I know who is winning and such .... its one cool thing about being in Melbourne, I know what happens before everyone in Perth :P
