i had a bit of a drift the other day hehe if u can call it that - I forgot it was a wet road so i took on that chicane near my house at my normal maniac speed and the back end did a drift to the left and ended up slightly on the curb - lucky it didnt drift to right cos that curb wouldve damdged my rims :P
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nah Ken I havent watched the series but there isnt much else on here in the hotel so thats it... its either that or pay movies :P
Niz... Its too late tonight, I have tommorow night then I am out of here Friday night. I think one days notice may be pushing my luck :) That and the fact that I can't think of any Melbourne guys that I know well yet???
Originally posted by Sneeza
Hey everyone!!!
hey Ken - what do you drink?? - i owe you big time
Drink ?? what happened to the
two fiddy sucky sucky j/k
Nah it's cool. I knew that drew would be of little help, the falcooon lover. hehehe
Cheers
Ken
Your on business expenses aren't you?
The pay movie channel sounds good.
Cheers
Ken
Niz - haven't really got a chance to "give it a bit". I had the  tyres done today, tomorrow morning castor arm bushes...and I was about to ask ken about discs???
I have washed and fully cleaned it out today - I do love it though!!
oops soorry . Will check prices tomorrow.
Got the Ricer back yesterday and have been working flatout on it. Had a guy look this arvo at it.
Cheers
Ken
Weirdo weiro.. hes quiet.. hang on no hes being strage... hes moving sideways left and right really quickly bobbing his head up and down. I think he wants attention or to come out of the cage.. bugga.. Hes too agressive atm so hes staying in the cage.
I just fell over and brused my other arse cheek. I fell down the stepps on the weekend and still suffering from that!!!
hehe brings back memories of how excited i was when i first got mine - should see how filthy it is now tho!! :P Cant wait to see it Liz :)
Put my Nismo sticker that aidwin gave me on today - its inside the car :D
Ken - ohhh the .... right how could I forget :P
nah what do you drink I want to get you a thankyou gift!
Yeah Andrew fully admits that he knows nothing abou jap cars.... I heard him talk to someone about fords and it was like he was speaking another language hahaha 351 this, 9" that hahaha
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
