i had a bit of a drift the other day hehe if u can call it that - I forgot it was a wet road so i took on that chicane near my house at my normal maniac speed and the back end did a drift to the left and ended up slightly on the curb - lucky it didnt drift to right cos that curb wouldve damdged my rims :P
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nah Ken I havent watched the series but there isnt much else on here in the hotel so thats it... its either that or pay movies :P
Niz... Its too late tonight, I have tommorow night then I am out of here Friday night. I think one days notice may be pushing my luck :) That and the fact that I can't think of any Melbourne guys that I know well yet???
Originally posted by Sneeza
Hey everyone!!!
hey Ken - what do you drink?? - i owe you big time
Drink ?? what happened to the
two fiddy sucky sucky j/k
Nah it's cool. I knew that drew would be of little help, the falcooon lover. hehehe
Cheers
Ken
Your on business expenses aren't you?
The pay movie channel sounds good.
Cheers
Ken
Niz - haven't really got a chance to "give it a bit". I had the  tyres done today, tomorrow morning castor arm bushes...and I was about to ask ken about discs???
I have washed and fully cleaned it out today - I do love it though!!
oops soorry . Will check prices tomorrow.
Got the Ricer back yesterday and have been working flatout on it. Had a guy look this arvo at it.
Cheers
Ken
Weirdo weiro.. hes quiet.. hang on no hes being strage... hes moving sideways left and right really quickly bobbing his head up and down. I think he wants attention or to come out of the cage.. bugga.. Hes too agressive atm so hes staying in the cage.
I just fell over and brused my other arse cheek. I fell down the stepps on the weekend and still suffering from that!!!
hehe brings back memories of how excited i was when i first got mine - should see how filthy it is now tho!! :P Cant wait to see it Liz :)
Put my Nismo sticker that aidwin gave me on today - its inside the car :D
Ken - ohhh the .... right how could I forget :P
nah what do you drink I want to get you a thankyou gift!
Yeah Andrew fully admits that he knows nothing abou jap cars.... I heard him talk to someone about fords and it was like he was speaking another language hahaha 351 this, 9" that hahaha
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
