  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
you shouldnt be touching noone Ken - your wife would kill u!
I have a very open marriage.
If I touch anyone and she finds out , the front door will be well opened ...
Cheers
Ken
I'm sure we could find some temporarily unused stretches of available bitumen, I was actually told to go out there by the local constabulary so I could do what I have to do where no one could see me, as far as accomodation there is budget accomodation around onsite vans / motels / pubs, I could get a reasonable amount under cover( under corrugated iron patio) if they were prepared to swag it, but you would need more than a sleeping bag . if your keen, give me approximate numbers and I'll make enquiries, would be good to see you.
haha premonition eh? well just as well u didnt go :P
Although i had a dream i got a yellow sticker as well but that was ages ago!! I was telling u guys about it on the way up to mickos one night.
Originally posted by SHUTO-BOY
heheh oh im turning 20 soon too, explain why its a downward spiral ken
Because your no longer a teenager. Am expected to start to act responsibly. Your parents will start saying things like
* when are you going to settle down. Do you have to go drinking EVERY night *.
16 year old girls go *ewwww* when you try and con them up.
Heaps more but alschiemers ( which I've had since 22 ) has kicked in.:P
Cheers
Ken
when i was 16 i was going out with a 22 year old i didnt go ewww haha!!
I want my own apartment - ive been thinking about it a lot lately and the urge to get my own "pad" has over taken the urge to do up my car - weird!! I'll buy one if i get the job im going to apply for and save up :P
Don't think swagging would be on the agenda but the bitumen road stuff sounds interesting. Any area of bitumen for circle work , ie large m/khana type area.
Cheers
Ken
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
    • Do you have the workshop Manuel? Sorry that's a Spanish waiter...I mean, manual? Some relevant pages>
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
