  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
you shouldnt be touching noone Ken - your wife would kill u!
I have a very open marriage.
If I touch anyone and she finds out , the front door will be well opened ...
Cheers
Ken
I'm sure we could find some temporarily unused stretches of available bitumen, I was actually told to go out there by the local constabulary so I could do what I have to do where no one could see me, as far as accomodation there is budget accomodation around onsite vans / motels / pubs, I could get a reasonable amount under cover( under corrugated iron patio) if they were prepared to swag it, but you would need more than a sleeping bag . if your keen, give me approximate numbers and I'll make enquiries, would be good to see you.
haha premonition eh? well just as well u didnt go :P
Although i had a dream i got a yellow sticker as well but that was ages ago!! I was telling u guys about it on the way up to mickos one night.
Originally posted by SHUTO-BOY
heheh oh im turning 20 soon too, explain why its a downward spiral ken
Because your no longer a teenager. Am expected to start to act responsibly. Your parents will start saying things like
* when are you going to settle down. Do you have to go drinking EVERY night *.
16 year old girls go *ewwww* when you try and con them up.
Heaps more but alschiemers ( which I've had since 22 ) has kicked in.:P
Cheers
Ken
when i was 16 i was going out with a 22 year old i didnt go ewww haha!!
I want my own apartment - ive been thinking about it a lot lately and the urge to get my own "pad" has over taken the urge to do up my car - weird!! I'll buy one if i get the job im going to apply for and save up :P
Don't think swagging would be on the agenda but the bitumen road stuff sounds interesting. Any area of bitumen for circle work , ie large m/khana type area.
Cheers
Ken
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
