no paul but if u look at hugh jackman and u - got similar sideburn and kinda funky wolfy teeth - wasnt mentioning anything about being hairy.
the comment wasnt meant to offend - its not a bad thing but i just see him on tv and there are some similarites :D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe i thought i only had wine but it cameback to me later on i also had - beer n CC - but i woke up bright as haha and everyone else was feeling sorry for themselves - i escaped a hangover!!
Originally posted by GTS-t VSPEC
I don't wear a watch, otherwise I'd feel bad, cause I'm always late for work:D
Maybe you should wear one, that's the point you feel bad if you gets late, then you wont late no more...
I have to say I get nasty to people who get late and blabbing on excuses. :D
Time is GOLD
yes must say when people arent punctual it really annoys me too - if your going to say u'll be somewhere at a time be there! if say a time and know ur going to be really there half an hour later - just say it from the start :D
no paul it really wasnt anything to do with the hair apart from the one on your head - its more the face!! The sideburns and your teeth! dont get all huffy on me cos that not what i meant at all :D
why do guys grow the patch of hair just under the lip - no many do but Ben did and this guy in the lift yesterday - looks like they have a dead caterpillar there or something - its awful!!
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
