  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ohh and btw , I got the standing ovation tonight in the T*** place circle work . I am sure you know where I mean , just up from the place you frequent.
Got it to do a rotate on the spot 4wd donut. Needed the wet rd to keep it going.
phuck , I damn near passed out with the g force.
Now I know what the WRC cars at forrest place must have felt like in the old days of victory donuts. Hehehe
Cheers
Ken
Originally posted by GTS-t VSPEC
So the ricer is going already:( It will give you money to buy another:D
Nope , with the changes in the rules ie. no one is complying R32's and the uncertainty of the 15 yr old , I will wait for a while and see what happens.
Cheers
Ken
Ken, I think my ring-lands have gone, will do a compression test on the weekend, see if it shows anything. But I drive sensibly too, don't know how it could happen:D
Yea , it seems to blow smoke on over run which means the vacuum could be drawing the oil up past the rings on overrun.
Could also mean that only your oil control rings are gone and the compression could be fine.
Cheers
Ken
Ken, let me know when your doing it and I'll pop down, I'm just around the corner:D
Wondered why Danny has so many fried tyres:p
they normally stay out of that street but hear them rip up and down past there shop.
It is usually only a spur of the moment thing.
Any , I'm off cos the missus has just slammmmmmed the door which is a hint.:(
Cheers
Ken
Oil control rings? Are they the second lot of rings on the piston? Is it bad? Should I put the forgies in sooner or later?
Nope , there usually the third set and are two thin rings with a wavy scraper thing. Not a real problem cos oil is cheap but it is telling you that the engine is getting tired. More boost and bigger terbs will kill it quick which is why I might as well get it done on mine now.
That and r and r the engine is like an 8 hr job.
Also finally found out mine has a nismo sprung twin plate and is in good nick so that's a bonus.
Cheers
Ken
I know people with cars in Japan waiting to come over when there 15yo, they could get screwed badly:(
Yep your right , might have bought a very expensive half cut.
And I will hi to the missus for you cos I'm blaming you for me still being up.:(
Wait till she sees you at Albany.lol
Cheers
Ken
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
