no im going to do it on the weekend - i need a couple of glasses of wine first to get the creative juices flowing - i tried the other night but i had brain block - i have to address the criteria etc etc.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Horay Niz we can be jobless together. Im doing the same, getting retrenched that is.
Not enuff work so i get teh raw end ebing the lowest in the chain :( ahh well it could be worse. Means to an end after all:D and i get to bum around for 5 mnths :(
Back to Uni to finally get my degree (commerce). Its a family business and its not doing to well atm so im glad to go (well greater good), its not the end. Ill be bored as hell though. I think ill start a car project to kill time.
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
    • Do you have the workshop Manuel? Sorry that's a Spanish waiter...I mean, manual? Some relevant pages>
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
