  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
Joe have some water..
Remeber ratio
4:1
4 bottles of water to 1 glass of beer :P
Christ !! is that right.
Looks like they had better build a bigger dam with the amount of booze I consume.
Cheers
Ken
Originally posted by Micko
Ken - you walked in just at the right time...
What is the diff between resistor & non-resistor plugs?
Steve told me not to get the resistor ones because they wont be as good. Most people seem to be using resistor plugs though:confused:
I dont think your on the right track there...
Plugs are all resistive....some low and some high??
Macka you ain't see me drink cos you only go to places where I have to drive home.
If I was staying or getting a lift home , well then you would see some......
Micko , unsure about the diff but think you need resistor plugs with electronic ignition.
Doesn't Hendo recommend BCPR7es-11 or something like that
Cheers
Ken
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
    • @GTSBoy iam not a mechanic so what could typically gone wrong? It can help my mechanic...maybe he just forgot something or something like that that could help. Yeah i thought. I took a LONG time to search for the right one. Yes i read about all of that and i give him a call about that. I look at those slave/master cylinders and they are not that expensive so i will be buying them anyway just to be sure.   @DuncanYou think it can be short? I double checked if that was a right one(it came with the clutch kit) Ok i will give him a call. Hope it is some sort of "little error" and not some "yeah the gearbox needs to go out" one
    • Temporary. Sorry about the inconvenience while we sort some issues.
