See ya Joe
I will talk to steve again next week about it. I checked the NGK website earlier & it said the same thing about a car with an ecu needing the resistor type (4ohm btw macka).
Said something about issues with idle, etc, etc.
Funnily enough there seems to be a miss at idle, but I took the car out for a lap between showers & it does seem to go better with the new plugs.
Also noticed that the rev limiter on the mines ecu is set somewhere between 8500-8800rpm. Strange thing is I never noticed that before cos I was sure that it was cutting in at 8200 as per the stock ecu that I had:confused:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
That should be bloody good fun Ken.
What time is it cos I got nothing on in the morning so I might come out & watch.
Behave yourself Clinton...you are not really in a position to throw stones
All day starting at 9am at the racetrack.
Instruction sess in the morning and hot laps after lunch.
I won't be taking any R's up cos one is at CRed and the other is going for pre sale inspection Tuesday.
Cheers
Ken
Should be interesting if it rains next weekend ken.
Would you still run the day if it is wet?
Shit yea, best time to run em.
Plenty sideways action with no tyre wear.
Cheers
ken
Originally posted by Pva_Glue
my mate just changed his spark plug on his soarer TT...
100.46 for irridium spark plug....$$$$$ char ching!
Why ?? Iridiums last about 50K KM while NGK std plugs ( bout $2.50 ea ) last bout 15K KM.
Cheers
Ken
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
