  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
ok with 5 secs looking at that dont buy resistive plugs
If you have a problem u can rectify it later as long as you find  A good Electronic Teck :P
Resistive plugs may cause u to have poor ignition bud  fact
Must be why Steve said not to go for them.
having said that, it seems to be against the norm but I trust his experience.
Plus for the $17.50 they cost, who cares if I need to change them for the others.
BTW - he put me onto 6's, not 7's as most other people use...
But you need resistance plugs if the car is electronic computer managed according to the tech article.
Or have I missed something ?
Cheers
Ken
Yeah go the colder plugs
Not so easy to start in the cold just pretend ur startin a carbed XD
hehe
But it helps stop pinging :P
errr 6 is hotter than 7 . NGK goes the other way to most heat range spark plugs.
Cheers
Ken
Cheers
Ken
You're right ken - i might go get a set of resistor ones before i put the car back on the dyno - then i can compare them to see if there is a difference whilst the car is on the rollers:uh-huh:
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
    • @GTSBoy iam not a mechanic so what could typically gone wrong? It can help my mechanic...maybe he just forgot something or something like that that could help. Yeah i thought. I took a LONG time to search for the right one. Yes i read about all of that and i give him a call about that. I look at those slave/master cylinders and they are not that expensive so i will be buying them anyway just to be sure.   @DuncanYou think it can be short? I double checked if that was a right one(it came with the clutch kit) Ok i will give him a call. Hope it is some sort of "little error" and not some "yeah the gearbox needs to go out" one
    • Temporary. Sorry about the inconvenience while we sort some issues.
