  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
How does it work then - i was told to gap them to 0.7 which quite small.
Does this mean i will get a hotter, more intense spark?
What is the normal school of thought when you increase boost?
Gap to .7 or .8 mm cos most of the modern plugs gap to 1.1mm hence the 11 on the end of the plug number.
The large gap is what gives a bigger stronger spark because it makes the coil build up a larger voltage to fire the spark across the gap.
The trouble is with turbo engines running larger than stock boost will blow the spark out while it jumps the gap ( simplistic terminology ) hence the need for a smaller gap , which then gives a weaker spark and is the reason why splitfire or cdi type ignitors are reqd on BIG boost engines.
Got it ?
Cheers
Ken
I think he was annoyed with how you addressed his indescretions...a little more tact would have been appropriate
Nah stuff it, just walk over and deck him. Hehehe
Tell us first so we can set up seats and get the beer and chips out.:P
Cheers
Ken
Got it ?
Cheers
Ken
Cylinder heat causes injector fuel to ignite before the spark flashes over :P
Thanks Ken - I had heard about the spark being 'blown' out.
Good work macka - blamed the wrong bloke...you are a tool (7/16 combination ring spanner if I recall):bahaha:
Maybe u should read more carefully,
I asked if he was the guy who hoons around my street picking up some girl he said yes
Im not going to change my driving habits because thats the way i drive and thats not going to change...
I accused no one
This plug talk is doing my head in...
So if I reduce the gap I should use a hotter plug to keep the actual spark the same?
Why do people go colder in most higher boost applications?
Colder plug means it will take heat , boost and thrashing better without melting or dropping the electrode off.
A hotter plug is used in colder conditions to aid starting or is used on a worn , oil consuming engine which would foul a colder plug.
Phucked with your head enough ??
Cheers
Ken
Anyway - who cares...
ZACHARY !!
I sure as shit don't sherlock.
Though if that spanker next door with the new loud exhaust on his rex goes belting down the street one more time....
Cheers
Ken
Right - almost done...
What this is telling me is that I should have gone to an NGK 8 (or stayed with a 7).
Micko , what plug exactly did Steve recommend.
I have checked my reference and Hendo told me to use
BCPR7ES -11 and gap them to .8mm
Cheers
Ken
PS I have and they work fine.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
