  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
that pic was taken early morning back in feb of when I first had the cooler put in :) Looking at my car sat next to niz's made me see how crap the stock car looks :( I have a set of side skirts and rear pods, which I should get on in the next few weeks, then I might have a look around at a new front bar. I'm not sure about lowering the car though as I have a high kerb to get over on my driveway and the last thing I want to do is scrape a front bar on it. Plus pauls got some 18x9 enkei rims (only 2 though :D ) for my rear then I can wack some 255 rubber on em :)
thank u aidwin - yeah im pretty happy with the way my car looks - apart from my back wing is cracked and my dad did a bodgy job trying to fix it haha. All it needs is so go fast bits haha
yes i did thanks Kyles - can i get back to u a bit later - paul says its alright if i still go down with him so yeah just give me a couple of days to get my head straight and i'll figure out what is best for me to do :) Thank u again tho - thats most generous of u & Troy :D
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
