  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
back
gotta love customers who drag u to the other side of town, decide after an hour they don't need to do what they dragged u over there to do and send u back
dipshit
oh and the skyline lighting up on the rear..
a place in QLD does kits or can get kits that replace the whole panel with a light that hooks into the brakes or rear driving lights.
was about $120-150 from memory.
im still waiting for a drag with my parents cars - auto against auto hehe so that way its fair anyway!! My folks cars havent had too much probs - Ryan asked me last night if dad go the go-kart fixed yet haha ansewer ..... no ...... dads lazier than me. For some reason he was only fixing it for ryan anyway.
aidwin - what sell my skyline for a F*** my parents would disown me - not too mention the shame i would suffer!!
I think i'll keep my line - some little teeny bopper can but the Focus Turbo
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
