  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well after have some thieves try on several occasions to steal my VL turbo a few years ago I can say that the ol 33 is very tightly tucked away.... They would have to be very very keen to try to take it.... But still you don't want to hear about these things soo close too home...
they pushed it 200m down the road
i have an alarm with door, boot bonnet, and glass brakeage sensors, also have an immoboliser, but they got past it some how.
They ripped out the ignition barrel to break the stearing lock so they could push it down the road.
It was insured with the RAC 3rd party fire and theft. They told me i have an escess of $1050 so i told em to get ****ed
the thing i had stolen where
panasonic 4x45 head unit
pioneer 220w 6x9
pioneer 4 channel amp
rockford fosgate 12" sub in sealed box
splitfire 5" monster tachoi w/shift light
plus not to mention how my car was left...
back seat was onm the road, carpet ripped up everywhere.
all panels wires etc ripped out and left hanging everywhere.
what i can get over is they stole the whole rear parcel shelf, they wheren't satisfied with just the speakers im guessing :)
Hi Guys,just came back from SST. We couldnt push the car to redline because the boost was creeping TOO much. So im gonna go back with a profec EBC and theyre gonna port my wastegate hole too. But without even pushing it to redline my car made 274HP,this was at erm 140+km/h i think
-so theres lots more potential left in them steve reckons
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
