i know nothing can be doen til sess times are released - but we need to make sure that everyone knows this is going to be popular and this is what every car club is doing therefore we do need to get in extremely early for the tickets so nobody is disappointed. I personally say an hour early.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
