  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
theres girls taller than me - one of them works at Dewsons Belmont haha :( a lot of girls are catching up to me in height these days which is good - not such a loner.
Yeah not a scratch - lucky he didnt have a passenger!!
301 was OK, but I thought we would get a little more but for some reason the curve dipped strangely near redline - steve reckons the rechipped ecu has got some strange timing at the top end.
All that aside - the best bit was the 10-15hp increase throughout most of the rev range, which translates into a much quicker car on the road:D
