oooo we going to have a bitch fight - u slap me i slap u back haha
hehe my dad asked how it went and he was disappointed with what it made too. I just do tell him these things to see if i can inspire him to make my car faster - he will have to if ben gets one!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Morning Bam bam wassup?
Oh get this remember that thing i worked on all last week? I gave it to the boss this morning and he sez
"whats this? "
"the report u asked for"
"i wanted the last financial year"
"yeh 2001-2002 right"
"nahh 2002-2003"
So here i go again, its not even the end of teh year, am i wrong? last financial year is 2001-2002 right huh uhh?
Originally posted by G0DF4Th3R
whuts a compression test and where can we get this done and what to look out for and how much will it cost and how long will it take and will you clean my room?
:) good one m8, u should start a thread!!!!:) get out the phone book and do a ringaround
hehe - yeah bambam i know but i have to save for europe or i'll incur my friends wrath!
Paul i aint paying for it - but its the only way u going to get anymore power out of it - i knew this day would come!
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
