http://www.r31skylineclub.com/forum/index....d=1168;start=75
Hehe, more funny jokes!
JOB TRAINING
In order to assure the highest levels of quality work and productivity from employees, it will be our policy to keep all employees well trained through our program of Special High Intensity Training (S.H.I.T).We are trying to give employees more S.H.I.T than anyone else. If you feel that you do not recieve your share of shit on the job, please see your manager. You wil be immediately placed at the top of the S.H.I.T list, and our managers are especially skilled at seeing that you get all the S.H.I.T you can handle.
Employees who do not take their S.H.I.T will be placed in Departmental Employee Evaluation Program (D.E.E.P.S.H.I.T). Those who fail to take D.E.E.P.S.H.I.T seriously will have to go to Employee Attitude Traing (E.A.T.S.H.I.T).
Since our managers took S.H.I.T before they were promoted, they do not have to do S.H.I.T anymore, as they are full of S.H.I.T already.
If you are full of S.H.I.T, you may be interested in a job training others. We can add your name to our Basic Understanding Lecture List (B.U.L.L.S.H.I.T). Those who are full of B.U.L.L.S.H.I.T will get the S.H.I.T jobs, and can apply for a promotion to Director of Intensity Programming (D.I.P.S.H.I.T).
If you have further questions, please direct them to our Head Officer for Training Special High Intensity Training (H.O.T.S.H.I.T).
Thank you,
Boss In General
(B.I.G.S.H.I.T)
Some advise for Paul!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
thanks :D
tough day. i had to actually work :D
Bayley my dad pokes the piss outta me too - but i always get him back twice as bad. haha he and i are going ot install the rear speakers hehe this is gonna be fun :D I told him it was a daddy daughter bonding sess and he goes "why dont u ever want to bond when im cleaning the pool"
"because u dont clean the pool!"
paul like ur going to be any protection for the girls when they guys from the broken hill come n and slap them around :D
I used to know a lady who used to work at a brothel as a receptionist and she had to get the girls outta drug induced comas n everything - so i dont think its your thing somehow!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
