  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Of crashing. Yeah it has an airbag - but when I hear a crash on the TV - I am pyshically sick, if I come up a bit quick to another car all I see is the accident. If I am driving and its stressful - like heavy rain or something I can;t breath properly. I never used to be like this - i was confident before
Liz I have been in more accidents than most ( usually as a navigator ) but found that by having confidence in your safety equipment and your self , the fear subsides fairly quick.
With the amount of times I have been in a roll ( bout 25 ) I worked out I am not destined to die in a motor car.
Cheers
Ken
Originally posted by SHUTO-BOY
i think we should organize some sorta wet skid pad day
-my friend fully crashed his s15 the other day because he lost traction and panicked,did the wrong thing and braked..and flipped his car
Unfortunately , there is no one in Perth who has a skidpan.
When it rains at the MC track , it's great fun though.
Originally posted by caminperth
lol @ ken.. after 25 rolls (separate occasions?!) then i'd say you have a correct hypothesis.. :D
Nah , 1 rotation is a roll. Was in a Triumph herald ( shaddup ) rally car that went over 31/2 times and caught fire.
Wrote off my rx7 rally car at a Sth Australia rallysprint with a 31/2 ( including 2 in the air ) .
Targa was 1 or so in 2001.
2 with my dad in a Datsun 1600 rally car
The list goes on...
Cheers
Ken
wow got some crazy friends hope the he comes out of his coma shortly.
hehe find a fwy liz n give it ago - only took me three days to find the accelarator but once u hit boost hehe you'll never drive like a grannie again :D
sneeza-just recently,
cam- we just need the water spray piping thingy at the edges of the area- u wanna open a drift school?
Drift school is coming.
We are putting together a proposal to run a drift series at the new MC complex at the airport.
Cheers
Ken
