haha chaos meant to sound that way :P
Alex - birdies like black too - so do wattle trees like to drop yellow pollen all over it that sticks when it rains - ooo and i often have a caterpillar on my car.
hey cam :(
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i often get in my car to go home and somewhere on the car theres a caterpillar - they must like it :( hehe dont mind caterpillars there cute usually still not on my car by the time i get home tho - blown off in transit hehe :P
nah zenah likes to sleep on the roof :) and its undercover so cant be hot - must be the fact she likes to piss me off haha. Yeah shes a very big n healthy female - vet always comments on how healthy she is.
Cool - just so i know what im kinda doing haha :D
mine was pretty fu(ked to say the least
woke up friday morning knee gave way as i was getting changed, havent been able to straighten my knee since so will have to go back to the orthopedic surgeon soon to get it looked at....
what makes thing even more annoying is that i only just had an op on my left knee now my right knee is fu(ked
hey paul, troy, niz and al...
troy - yea, need that suspension changed if i want to get into drifting.. but the current setup is still good enough to have alot of fun on the way back from toodyay! :D
paul - no drams with the close following - it's all part of the fun.. just don't touch me.. :)
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
