  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Hello Kenny:D
Ken, when running an engine in do you use mineral oil first?
err , you mean like a non synthetic , then yes cos you need to let the rings bed.
Cheers
Ken
btw , the ricer is going to be a racer cos the racer can't go racing...
Aidwin, There are enought nerds around, don't need you aswell:D
Ken, If he runs low boost it will be ok for a while:D
yea but the old
* if some is good there more is better * Micko will come in and there goes the engine :)
Cheers
Ken
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
