  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Bummer Ken, do you think the ricer will cope? Non-synthetic is mineral isn't it?
yea pretty much.
Use a cheap mineral oil with not too many friction modifiers in it and change at about 1000Km
The ricer should be ok but beats watching from the sidelines.
Won't win but hopefully will pick up some points.
Cheers
Ken
Ken, If I join WASCC, on the track days am I allowed to take a passenger?
Umm , not sure , don't think so unless a recognised WASCC instructor ( of which I'm not ).
Cheers
Ken
Sorry guys - I'm back...
yep Ken - looks like I'm going 2530's - I know that other things will need to be upgraded - I assume you're using the bigger injectors you had on your project?
I know of other people getting away with standard ecu, etc with these turbos (i.e. Brett Hackett) but I will try to push for everything whilst I can get it:D
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
