  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken, I take it you'll tow the Ricer, and bring the Maverick?
Yep so we will have a trailer to bring the broken R33's home on ( for a fee ).
Gotta pay for my new engine somehow.:)
Cheers
Ken
Originally posted by Micko
Sorry guys - I'm back...
yep Ken - looks like I'm going 2530's - I know that other things will need to be upgraded - I assume you're using the bigger injectors you had on your project?
I know of other people getting away with standard ecu, etc with these turbos (i.e. Brett Hackett) but I will try to push for everything whilst I can get it:D
Std ecu ???
He bought my Power FC off me.
Cheers
Ken
Ken, I was hoping you pull the handbrake as I was going around Novus:D, get some drift action:p
yea I suppose I could.
You need all the help you can get:D
Cheers
Ken
yes only half of my kit has arrived, the other half will be here by thursday or friday
then it's full steam ahead hopefully next week, well it better be or i will bring my friend con the grocer and complain loudly
adrian :)
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
