  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Alex - jus tadding a bit of days of our lives into the room - have u forgotten the roasting i gave paul the other day - trust me its better for all concerned when we are sweety etc. Besides least we are mostly all talk unlike Troy n Kyles haha
Lighten up Hun!
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
