  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Brett - they are just smilies ur getting carried away - focus on the cars man :D
Paul - well how do we say your not in trouble then without molesting the boy :) unless thats what u want :aroused:
Its a Mastercard
55 interest free
4.9% pa for the fist 6 months (introductory rate)
No yearly fee
I just applied so i dont know much yet. 5-10 days to process.
I plan to use my current credit card then transfer the balance after my 55 days is up. then i get the 4.9% as opposed to my 12.75% i have at the moment. I wont get the 55 days cause a transfer is classed as a cash advance so u dont get the freebies.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
