  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
lot of people talking about internet marriges n dating at the moment - sorry my boss n someone were just talking about how someone they knew did it and Billy's sister did the same even tho apparently she's really good looking haha he was not impressed by her method of dating.
How could u go n marry someone u havent properly met :P
adrian trust me - once u broken up once it aint going to work. You will be unhappy for a while but u will be a lot happier in the long run :P
Besides Shaft shouldnt be too hard for u to get the girlies!
hahaha niz, apparently some chick who works at the gym likes me hahahahaa coz i now one of the sales concusltants there pretty well and he was telling me that she was asking bout me lol hahaha but maybe i just stay single for a while :) after all i'm only 17(turning 18 in 2 months and 10 days)
yeah paulie me and her were best friends b4 we hooked up, i think it's best we go back to that :)
adrian :P
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
