  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paulie, i see you want to be like me and get a ***** front bar ;)
BITCH :P
i found this awesome picture of the original shaft :) but it is a tad to big to fit into my avatar :) anyone got software to resize it with? for me :)
adrian :)
Start with the basics: Ninja scroll and Maccross Plus, if u like those come back and ill suggest some more good stuff for ya. If u want something on disc try "cowboy bebop" all the above should be avail at ure loal video shop. Well if u live in winthrop :P
