  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
indeed i am going down south. Hmmm if we come back on Sunday may catch u Sunday sess but if we dont doesnt matter no loss maybe too tired for one by then anyway.
6 months long - i envy u!!!
Ha Blue Submarine 6? yeh got that all on disc $60 bucks a pop, 1 ep per disc, 4 eps total(or was it 6??). Bloody ADV. Was cool but didnt really go anywhere.
Yep much working on car and stuffing around, it will be sweet:D
"Samurai pizza cats, we hope u liked the show cause its the best that we could do"
"Samurai pizza cats, if you could do any better then wed leave it up to u!!"
Hehehe ure right it does get stuck in ure head.
COMPRESSED INTO 1 EPISODE!!!!! yeh and while were at it why dont we just make the son of rajab of the rind into a single 1 hour movie, and maybe compress starwars into a single feature including the dumbass christmas special!!!!!!
U really gotta watch the whoel thing eh, ep 23 the writer went off his prozac (true story) and the plot goes off on a tangent.
In my opinion EVA was the best thing ever on a square box
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
