  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I find the problem with dragon ball z is that because I didn't watch it from the start it doesnt make alot of sense... I understand the concepts behind it, but if you don't know the history of the characters and how they are linked together its bloody confusing.... like when I was in melbourne I watched and episode in the morning where two characters joined into one permanately by joining ear rings.... and if I watched it the day after I would have just thought who is this guy?? And why is he having so many problems with himself :)
Yeh its getting taht way buts its always fun too.
I actually used to go to an anime fan club called JAFWA (japanese animation fan club of WA)on sat nites at curtin. Had to give it up cause the clientelle drove me insane, well almost as much as the shows did. Regardless they have all the best stuff first, some real harcore fans there.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
