  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
does that extreme autos or what ever its called have a website
a mates checking out cars there tonight, hes gonna try a FTO and a skyline of course i told him to forget the FTO
but the nancy boy is worried about insurance.
though he was quoted $750pa for a 95 180sx so his record must be pretty good
