  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hmm , no pwptpf and the Whoress.
Must still be coming the long way home from Albany.
For those interested , Paul , Lauren , Troy , Kyles , Myself and missus were at Albany for the Hillclimb and the motorkhana.
Danny ( GT500 ) and g/f came down for a few hrs on Sat.
I ran the ricer in the Hillclimb and won it ( yea , phuck me I was surprised as well )!!
Did the khana with the missus driving as well and finished who bloody knows where but had a good time.
pwptpf took plenty of Vid with my camera ( sorry , no in car this time ) so Neo maaaaaaaatttteeee!
can you turn it into something useable ????? huh , huh , please ??
Cheers
Ken
Steve was adamant that the wholagans 470 hp atw GTR would hose everyone.
Jamie couldn't get the power down , hit a cone , fell off boost , all of the above.
John only got one run due to delays and when I got back at the finish after being to the Khana , I found I had the fastest time.
Ahh well , it's all good.
BTW , Ivan's ( Speedworks corolla ) is no more. Hit the bank , smashed the lhf wheel and tipped it down the road on it's side.
He's OK but the car is a mess.
Cheers
Ken
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
