  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Back later if anyone's here - gonna go watch KillerT on the dyno - he's gonna pump the boost up to 1.5bar:D
Seeya Micko. I assume that is at Hendo's cos he is the only nutter I know who starts work at 9pm.
Cheers
Ken
Cheers
Ken
Originally posted by angel
4th glass and positively tipsy. Definately no intelligent conversation comming from this corner. Can't wait to have a night out with all of you. I wont drive and I promise to reach criminal levels of intoxication! Ken, look after me babe! Someone will have to.
Hope your better than Niz at it.
Went to Albany and the pub on Sat , she was in bed by 9pm:D
Comming is spelt with one m
as in * oh , I'm coming *
out that is.:D
cheers
ken
Won't be in bed early, waiting for a friend to come over. And husband should be here soon.
Husband ??
Ahh , shoot.:D
Just when it was getting interesting
Chance for what macka ??
Cheers
Ken:D
