  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by angel
Thinking of going to bed. Or doing my accounting homework. or bed. Hmmmmmm
Gee , I don't know , comes on all tipsy with her mind in the gutter.
Leaves everyone heavy breathing ( ok , ok , leaves ME heavy breathing )
Then nicks off to bed alone.
Damn it , that means I have to go back to talking to the whores again.:D
Cheers
Ken
No Ken, a friend who knows just how to get me when I am drunk. I THINK I regret a few things I said. He always manages to make me feel like I am the most stupid person on Earth. Don't quite know if he is laughing at me or with me.
Hmmm , when I'm drunk , I'm the smartest person I know.
Pity no one else shares that view:D
Cheers
Ken
