  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i think i'll stay off salmon for a while - when i was eating it the resturant yesterday i thought something wasnt quite right with it - and i think thats what made me sick. Soup n a roll would be yum - specially potato and leek soup.
i dont know shall find out from mum - i havent had any sms's cursing the state of the house yet so probably not! Yeah im going to go home first - let my cat out before any accidents occur :P
