  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
A man walks up to a bar with an ostrich behind him, and as he
sits down a small cat jumps up on the stool beside him.
The bartender comes over, and asks for their order. The man says,
"I'll have a beer" and turns to the ostrich. What's yours?" I'll
have a beer too" says the ostrich. The cat says, "I'll have a half
beer, but I'm not paying for it".
The bartender pours the beer and says "That will be £6.40 please,"
and the man reaches into his pocket, and pulls out exact change for
payment. This happens the next evening also.
The following evening the trio enters again. "The usual?" asks the
bartender. "Well, its close to last orders, so I'll have a large
scotch", says the man, "Same for me" says the ostrich. "I'll have a
small scotch, but I'm not paying for it" says the cat. That will be
£12.35", says the bartender. Once again the man pulls exact
change out of his pocket and places it on the bar.
The bartender can't hold back his curiosity any longer. "Excuse me
sir, How do you manage to always come up with the exact change out
of your pocket every time" asks the bartender.
"Well," says the man, "several years ago I was cleaning the attic
and found an old lamp. When I rubbed it, a Genie appeared and
offered me 3 wishes. My first wish was that if I ever had to pay
for anything, I just put my hand in my pocket, and the right amount
of money would always be there." "That's brilliant"! says the
bartender. "Most people would wish for a million dollars or
something, but you'll always be as rich as you want, for as long as
you live."
"That's right!, Whether its a pint of milk or a Rolls-Royce, the
exact money is always there" says the man. The bartender asks, "One
other thing sir, what's with the ostrich and the cat?" The man
replies, "My other two wishes were for a bird with long legs, and a
tight *****
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
