  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
different dan that your thinking of brett i thinnk
25gtt
i still think he should stick with the t3/t4 hybrid he wanted first.
what would be kewl is if he could get one made to the same specs as whathisname from SA.
hey paulie did u see that guys thread in performance section about the guy with same mods as me running 1.1bar and getting 301rwhp ???
I would probably join his offer of joining the fitness club, but only if we got together as a group and did it.... I have no motivation to go to the gym on my own....
I can't believe the Supra was an NA!!!! What about the ferrari!!!!!
