  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i got offered an intercooler by the guy driving wine red line at City West - he bought it for it and doesnt need it anymore
hehe dodgy arabs - damn new plenty of them in the car industry wouldve just got one ripped off one of the imports - damn it wouldnt have to be paying for half of this stuff!
alex - you've turned into a full whore.. the dark side has taken you.. i must work due to the nature of my open plan office.. we're moving offices this weekend so hopefully next week will see more whoring from cam.. :O
paul - that ok with the tyres?
