  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
D'Oh just invisaging it makes me laugh tho - a little baby on board sign haning off ya back wing - and a whinging pommie missus in the passenger seat hahaha - little chocolate fingers smeering grease all over the back haha
hehe u can look at this way paul - its a bit like why people watch reality TV - we like to see people put in interesting situations beyond their control :( nothing really unusual about it.
Joe u live in swanky lawyers building we could imagine!
