  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Boostzer - you use lemons to get rid of the smell - rub the juice on yer hands then wash them.... it goes away. Or even better - use a garlic crusher and chop onion the correct way and you won't get the smell!
Paul and Brett - welcome to come over any time for dinner!
