  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Had a look at the nokia one and the panasonic had a bigger screen and seemed to take clearer pics.. i know it's not going to take pics with a 5 megapic resolution or anything like that but was wondering if anyone had a sample of what the pics look like..
