  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ouch final notice - East Perht Cop centre will process it for u. haha becareful because they accuse you of looking like your going to steal stuff in there - i was looking at the window - waiting for them to print out my ex's traffic convition bible - and this copper comes up to me and goes "they're not worth stealing luv" and im what tha???? so i really look that type - it was soooo rude!
