  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
u no like bamie? chicken breast is good for u and yum
mmmm hotdogs yum too :P
Then we had this conisuierre icecream that paul introduced to me - its called english toffee - u gotta taste the stuff its like heaven! :drooling:
hehe bamie tomorrow really i will start - i'll be out for most of the day so the temptation wont be that - i was in a real bad mood today so i went out and bought comfort food ...... i even ignored the rather gorgeous video shops guy ..... i think he likes me ..... but probably after today he's changed his mind!
Soroity Boys ..... someone said it was good - it was ok similar to Van Wilder but Van Wilder was better.
We've got a small video shop - all the good stuff gets takenon friday night so ur just left with shit to choose from on saturday haha - i used to go in there all the time for the scenery ..... i swear that guy thought i probably had no life but was only there for a perv haha
Hey Epoch
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
