  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hmmm , I coild say what paul said but from me sounds like a perverted old man
* ohh , I AM a perverted old man *
Ohh well , I will come round and give you a massage then:D
Cheers
Ken
ps , just joking Troy if your reading this:D
