  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My fwd is no fun ever. I can put my foot on the brake, other foot fully on the accelerator, and go nowhere, just revving. When brake is released, car still goes nowhere for another 5 secs. Hmm, disappointing, much more fun in the Commodore. Blame my Dad for that comment! He took my damned Skyline. I shall never be over it.
Gotta go anyway, have work to do,
cheerio!
Originally posted by Nizmo
Bam - DO NOT TOUCH HICAS!!
u need a special lock kit to disable it - u go pulling plugs out willy nilly and ur car will be unable to drive - go ask strich9 he did it. SPECIAL LOCK KIT NEEDED!!
That is correct.
Thanks for pointing that out Niz, I almost forgot, well, tried to anyway....I pulled out the HICAS computer located in the boot under the parcel shelf. It disabled power steering completely, and was a BITCH to drive.. hehehe. Don't try it.
I _DIDN'T_ However, try to pull out the three little plugs on the HICAS actuators under the car (near the diff) to disable it. Hmm.. That get's me thinkin....
*It's time to watch Kym do something stupid and be the guinea pig again!!*
off i trot....
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
