  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha yeah what is the world coming to kym? u not switching sides on us are u :D:)
Yeah Bam he gave me and Liz this piece of advice - never eat a kabab on your first date - in fact just dont eat on your first date haha
If u do, u will definitely feel the improvement in handling, especially cornering. I have JIC coilovers, but I think Koni will do the job and are much cheaper. If you go for a Japanese brand better make sure it is more common than JIC, like Tien otherwise if its broke, its hard to fix :D
