Originally posted by skyzerr33
u can't expect much from a ford boy though kym
and kym u can't be jealous u window shop way to much to get upset if some guys cracks onto your lady
Ford boy is he? well that settles it! :bahaha:
Window Shop ? dam straight everyone looks at other people, like angel said, it's human nature! I love my girlfriend, and we trust each other, i dont get mad when some other dude cracks onto her, as she generally makes him buy her a drink, then says she has a bf and brings it to ME! (yeh, score!)
And likewise when another chick comes up to me! it's all trust, and there's other things in life to be worried about, all this jealousy shit is sooo not worth it.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
that would be JB R33 lauren nice car show car for pioneer
That's Jason's car yeah.... but his car is WAAAY different to mine in every way... not easily mistakable....
heard a rumour he wanted to sell it for $30k a while back.. :bahaha:
i didnt get a close look - just saw the white line and white stripe from the distance -hadnt seen any others with those so i assumed it was urs .... i know otherwise now :)
my mum says she can window shop but not put anything on lay-by :)
Yeah but if u do really lcare for someone u cant help but get jealous thats also human nature - but theres always a right way and wrong way to handling things.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
