  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
niz there is an orgie going on in my pen jar, a rubber that kid of looks like a small dildo.. a pencil, a pen, and a perment marker, and a white out rolly thingy.. i think its a gay orgie.. no sharpner!
thats to much info missy x rated
