  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
man why are all the guys we get around here ugly! work would be so much more pleasant to come too if there was some god damn talent around here!
because you work in government.
no one works with hot people anyway. and if there are hotties, theyre always the first to leave......just the way of the world!
:looney:
Skippers used to have lotsa hotties hehe
New Town did but they were all in Lexus and they all left me by my lonesome :P
In fact i think this is the first job ive had with absolutely noone to perv on!
al - actually think we worked out what was wrong with it.. i may have contributed and impressed the boss so could be some more bling.. :D
in all seriousness - this little excursion was meant to be a test me thinks..
any prados or landcruisers up there? if they are Rio Tinto ones i probably licensed them :) and driven them at some stage .... useless bit of info
Anyways im bored too! as i said the most exciting thing i get to do is burn cd's and its taking 10mins for each one to burn :D
niz - there's a few.. you wouldn't want to drive these ones again tho.. :D
burning cds? hmm sounds like u have a case of "needanewjobitis" cause it seems to come and go with you - but won't be cured till you get off your ass and go looking and find something to make u happy..
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
